K
I have an application with IC693TCM303 modules to control temperature. GE Fanuc says that these modules can read until 1050 C degrees. But in my app when the module reaches the 600 C deg the readings in the versapro software goes down. Of course i checked all the parameters and module configuration and the same. Also I put a RTD compensator and the same problem. Just for compare I connected a Loop controller (omron) wich one can reach 700 C deg with out any problem. Can anybody help? Thanx
