How to get data from ABB ProControl on VAX
T
Tom McAuliffe
Need to access data from an ABB ProControl Plant Managment Software database which is running on a VAX (I think its running VMS). I want to be able to move the data over to an NT system. I located an unsupported ABB ODBC driver vintage 1995 but not sure how good it is. Any suggestions?
W
Weiping Ying
If you are going to request PMS data once in a while, the ABB's ODBC driver works. But the performance is not good, if you have a lot of data to be transferred. That's because ODBC is not designed for real-time applications.
If you are talking about transfer PMS real-time data periodically, you have to find another way. For example, you can write a DDE server for PMS database in VMS and transferring data from PMS to NT application using NetDDE. That's the way we did for one of our project.
