I want to use 24 voltage from DRUCK DPI 610 as a power source to calibrate HART transmitters.
If I use DC power supply I need to use 250 ohms so that the Hart signals wont get filtered by Low pass filter inside the DC power supply.
How ever i want to use 24 volt from DRUCK DPI 610, here the 250 ohms didn't help. The circuits inside Druck may be different from DC power supply, Instead of resister what can i use?
I want solution please
Thank in advance
Thank in advance
