I have recently had to disable an alarm in an analogue output card channel due to it causing an error in the PLC Software. The Analogue output in question, operates a modulating process valve. This is done by the PLC using a PID linked to temperature control.
As far as I am aware the valve seems to be functioning without any problems (4mA = Closed 20mA = fully open )
however in the PLC I/0 as seen in the control logics project window, I have had disable the internal alarm for this output channel to prevent it from sending an "Analogue error" message via a HMI Screen.
My question
What does this internal alarm actually do. (It must monitor the 4-20 mA signal somehow. (There is no other feebback)?
My question
