Sir,
We have 2 Mark V frame V gas Turbines @ 20MW running on Naphtha part Load.
During each start-up after firing established from around 3000 rpm gas turbine exhaust temp increased drastically to 480 Deg C & then came to 280 Deg C for more than 5 min ( nearly 200 Deg C). Sir is it advisable.
& once during start up in diesel engine engaged mode vibration went up to 18mm/Sec for 3 min. Then after some time it came to normal mode. Now it's running smoothly @ 3 mm/sec. Sir can you clarify my doubt after that much vibration how unit will run smoothly & what may be the reason behind that?
