Is there standards/guidelines published for grounding the shield when using shielded cable for EMI? I have heard arguments to ground at one end only; others say to ground both ends and use
capacitor to combat ground loop problems; still others say use resistor instead. Which is correct/best method? Is it based upon the signal frequency? I realize that much depends upon the
application but some rule-of-thumb guidelines based upon time proven testing/experience would make for easier design decisions.
David Baird
Senior Controls Engineer
Gem City Engineering
(937) 223 - 4600 ext. 1456
[email protected]
David Baird
[email protected]
