Greetings ...
In najaf gas power plant-Iraq, we have aunit designed by ALSTOM type GT8C2 55MW
cotrol system ABB Egatrol AC160
This unit consist of 18 combustion chambers .. in the center of combustion ( pulstion sensor type cp10x)
kindly I would like to inquire about a problem that occurred in reading pulsation sensor , which is the reading not stable , when the unit is in operation as when the load is gradually increased , the values rise normally
the main problem .. when the load is raised to 40MW the problem it begin , as the value of pulsation is normal , after a certian period the value of pulsation is fluctuate and swift up 40mbar and down 28mbar
does the control valve and Temp. after turbine TAT related to pulsation ?
please help me to understand the philosophy of the pulsation sensor and solve problem
I attached picture to explain the status
