Seeking advice on what I need to provide motion control to a prototype 96 inch vinyl cutter. Cutting in a straight line and the ability to cut in the opposite direction. I'm planning on using Thomson lead screw/ball screw 1/2" dia. rod. The drag of the cutter is about 3 Lbs. What type of step motor should I consider? How do I find the appropriate drive sprocket for gears or a belt that will be the right size to attach to the step motor and Thomson rod? What do I need off the shelf for a controller and programing unit to program the motor to run a certain number of turns, pause and reverse it's polarity and return to it's start point? Any help would be greatly appreciated....Mike
