In our power plant we are in the process to reduce the active power imbalance between grid market set point and actual active power production. The main reasons for these imbalances are the droop characteristic. 4 % droop means that an increase of frequency 4% will mean increase a n increase of load from 0 to 100%, so at TNH of 100.3 you are at full speed no load, and at 104.3% you will be at base load (maximum BASE load).
The question is which constants of Mark VI logic implement the droop speed control? also the droop signal is changing all the time. I guess this is the constant settable droop......Any help is very welcome...
