When unit reaches zero speed, FSRSD on <R> and <T>
ramp to 100%. FSRSD on <S> stays at zero. Voting
mismatch on FSRSD is captured on diagnostic alarm.
Unit is "Ready to Start". (Master reset will ramp FSRSD to 100% and next run always successful.) If master reset is not done, the next "start" results in a immediate "master protective start-up lockout" numerous voting mismatches on <S> the unit does start successfully and come on-line.
Have replaced relay 4S (4 times at the suggestion of others...), replaced HRDB board slot A of RDM (thought we had it pegged with that effort, but it tells us "sorry, please try again!")
Have examined pulse rates for turbine speed and fuel flow divider speed. (appear OK, definately have 0 RPM on fuel flow divider after fuel cut-out and zero speed on TNH at zero speed.)
This problem is only occurring on <S>.
and a recent "interesting" finding-> the above scenerio only occurs when unit is in "remote",
running unit locally in "Auto"... no problems!
Possibly 28 volt relays associated with "Remote"
(L43R1 or L43R2)?
Other possibilities?
Many Thanks!
Anon
(L43R1 or L43R2)?
Many Thanks!
Anon
