I have this cable connected to an inline tap, the control cabinet schematics calls this a "programming drop". Since this cable has a pre-assembled DB9 Male connector on the opposite end from the tap, I am wondering what pin goes to which wire. According to Schneider all drop cables used on an inline tap uses two sets of twisted pair cables. One set of wires is color-coded white and orange, the other set is white and blue. Each pair has a bare shield wire. I have an illustration of how the wires are connected in the tap, what I need to know is which pins are used in the DB9 connector. The connector has all 9 pins but all 9 could not possible be used.
