Good day. I have been looking for materials wherein the Moment of Inertia of the load is being considered in the design of motors. I have seen "inertia matching" in some books. It says that, in the motor-gearbox-load configuration, the Inertia of the load "as seen" by the motor should be the same as the inertia of the motor in order to obtain maximum acceleration. This inertia matching will be dependent on the gear-ratio of the gearbox. My question is this... If there is no gearbox, what will happen to the motor-load configuration if the load's moment of inertia is too high? Or, is it ok to put whatever amount of moment of inertia as a motor load? Including reference materials in your response will be very helpful. Thanks in advance.
This is my email just in case.
[email protected]
thank you very much.
[email protected]
