T
The MOSFET IRFZ44N is driving a external relay (Freewheeling diode might not be used across the relay coil. the coil will draw a current of 200 mA) which in turn will be used for driving START solenoid of generator or driving hooter or driving a contactor. The supply is 12 V / 24 Battery. I am driving the mosfet using a ULN (driving uln thru microcontroller) with pulse amplitude of 5 V DC(max).
Connection is as follows :
The output pin of ULN is pulled up to +5V dc thru 3.3k resistance. The drain of mosfet is connected to one side of external relay and other end is connected to Battery +Ve and source is connected to Battery -Ve.
I am getting frequent failure of this mosfet from the field. What could be the reason & what way i could protect the failure of mosfet. Pls suggest.
rgds,
rgds,
