Hello everybody:
I am working on a humidity generator project and would like to implement a PID to control the temperature and humidity in a chamber. I had earlier downloaded a source code for the PID algorithm from T. Connolly (thanks boss!!!). I modified it as much as I could to match my project but I cannot figure how to tune it. Please take a look at it and email me at [email protected] if you have any suggestion. My sincere apologies if I killed your code Connolly...
#include <stdio.h>
#include<math.h>
struct _pid {
int pv; /*integer that contains the process value*/
int sp; /*integer that contains the set point*/
float integral;
float pgain;
float igain;
float dgain;
int deadband;
int last_error;
struct _pid warm,cold,*pid;
int process_point, set_point,dead_band;
float p_gain, i_gain, d_gain, integral_val,new_integ;;
pid_init
DESCRIPTION This function initializes the pointers in the _pid structure
to the process variable and the setpoint. *pv and *sp are
integer pointers.
void pid_init(_pid *warm, int process_point, int set_point)
struct _pid *pid;
pid = warm;
pid->pv = process_point;
pid->sp = set_point;
pid_tune
DESCRIPTION Sets the proportional gain (p_gain), integral gain (i_gain),
derivitive gain (d_gain), and the dead band (dead_band) of
a pid control structure _pid.
void pid_tune(_pid *pid, float p_gain, float i_gain, float d_gain, int dead_band)
pid->pgain = p_gain;
pid->igain = i_gain;
pid->dgain = d_gain;
pid->deadband = dead_band;
pid->integral= integral_val;
pid->last_error=0;
pid_setinteg
DESCRIPTION Set a new value for the integral term of the pid equation.
This is useful for setting the initial output of the
pid controller at start up.
void pid_setinteg(_pid *pid,float new_integ)
pid->integral = new_integ;
pid->last_error = 0;
pid_bumpless
DESCRIPTION Bumpless transfer algorithim. When suddenly changing
setpoints, or when restarting the PID equation after an
extended pause, the derivative of the equation can cause
a bump in the controller output. This function will help
smooth out that bump. The process value in *pv should
be the updated just before this function is used.
void pid_bumpless(_pid *pid)
pid->last_error = (pid->sp)-(pid->pv);
pid_calc
DESCRIPTION Performs PID calculations for the _pid structure *a. This function uses the positional form of the pid equation, and incorporates an integral windup prevention algorithim. Rectangular integration is used, so this function must be repeated on a consistent time basis for accurate control.
RETURN VALUE The new output value for the pid loop.
USAGE #include "control.h"*/
float pid_calc(_pid *pid)
int err;
float pterm, dterm, result, ferror;
err = (pid->sp) - (pid->pv);
if (abs(err) > pid->deadband)
ferror = (float) err; /*do integer to float conversion only once*/
pterm = pid->pgain * ferror;
if (pterm > 100 || pterm < -100)
pid->integral = 0.0;
else
pid->integral += pid->igain * ferror;
if (pid->integral > 100.0) pid->integral = 100.0;
else if (pid->integral < 0.0) pid->integral = 0.0;
dterm = ((float)(err - pid->last_error)) * pid->dgain;
result = pterm + pid->integral + dterm;
else result = pid->integral;
pid->last_error = err;
return (result);
void main(void)
float display_value;
pid = &warm;
printf("Enter the values of Process point, Set point, P gain, I gain, D gain \n");
scanf("%d%d%f%f%f", &process_point, &set_point, &p_gain, &i_gain, &d_gain);
//process_point = 30;
//set_point = 40;
//p_gain = (float)(5.2);
//i_gain = (float)(0.77);
//d_gain = (float)(0.18);
dead_band = 2;
integral_val =(float)(0.01);
pid_init(&warm, process_point, set_point);
pid_tune(&warm, p_gain,i_gain,d_gain,dead_band);
pid_setinteg(&warm,30.0);
//Get input value for process point
pid_bumpless(&warm);
int count=0;
while(count<=20)
// how to display output
display_value = pid_calc(&warm);
printf("%f\n", display_value);
//printf("\n%f%f%f%f",warm.pv,warm.sp,warm.igain,warm.dgain);
count++;
#include <stdio.h>
#include<math.h>
struct _pid {
float integral;
float pgain;
float igain;
float dgain;
int deadband;
int last_error;
pid_init
integer pointers.
struct _pid *pid;
pid = warm;
pid_tune
pid->last_error=0;
pid_setinteg
pid_bumpless
pid_calc
int err;
else
return (result);
void main(void)
pid = &warm;
//set_point = 40;
dead_band = 2;
int count=0;
while(count<=20)
count++;
