My turn to ask a question; I am running some tests with serial PPI to a S7-224 over cellular (GSM/GPRS) and it doesn't appear to work. One can set a timeout under the "Set PG/PC Interface" of 1/10/100sec, but that may be just the overall timeout before a response.
The issues seems to be that PPI has the "Tsdr" requirement of 22-40 bit times during which the slave MUST return the ACK. At 9600 baud this is roughly 20-40 milliseconds; which is impossible over cellular where round-trip delays will be in the 700 to 2000 millisecond range.
Does Siemens offer some tool or setting to overcome this protocol limitation? How do people access Siemens S7-200 over radio or satellite systems where latency is higher than normal? Would a CP243 via IP allow for higher latency?
Many Thanks
- Lynn A Linse, www.digi.com
Many Thanks
