E
Dear CSA and All,
I would like to calibrate the distillate fuel 65FP servo, thro the "calibrate" mode facility in Mk6 system. [GE Fr5 Mk6 control]. Unlike, the Gas servo valve calibration, where we set the servo valve output values thro "manual" set point and then compare the error with the LVDT feed back. How can we make use of this procedure for the 65FP servo, where we have NO LVDT for the feed back and there is NO stem (scale marking) on the 65FP servo to see the movement of the servo? We have only Flow divider as the feed back and our turbine don't have the auxiliary pump and need to run the turbine in "crank" mode for the calibration within limited time. Please guide me for the proper and effective calibration of the dist. fuel system.
Thanks..
Thanks..
