Hi everyone,
I need to interface an external PC with a Toshiba T3 CPU (model PU326H) in order to read data from several 'F' registers.
The external PC sends data via RS-232 to a RS-232 <-> RS-485 converter, then that converter sends data via RS-485 to the Toshiba T3 PLC "Computer Link" port, located on the bottom of the Toshiba T3 PLC.
The setup I have enabled so far is as follows:
Select System Parameters
Inside Computer Link Setup, choose the station (=1)
Inside Computer Link Setup / Communication Parameter choose Baud rate = 19200, Parity=None, 8 data bits, 1 stop bit
See full setup visible from here:
https://www.dropbox.com/s/uoqfj3v08c3dp6u/PM3 overview for Toshiba PLC experts.pdf?dl=0
The problem I am having is that while I can send data via the RS-232 converter, no data is sent back from the Toshiba PLC.
Has anyone ever setup the Computer Link port on a Toshiba T3 PLC? Any clues as to what is causing the issue I am observing?
Any help is appreciated, thank you.
Regards to all members.
