Morning everyone,
I'm working on building a malting machine (see the project here http://osuminimalter.weebly.com) and I need to purchase some valves for flow control. I have a National Instruments current output module that can output 0-20 mA or 4-20 mA.
I need to be able to control the flow rate of a hot water stream, which will mix with a cold water stream to attain the desired temperature. I also need to control the flow rate of steam, supplied at 80 psi, going through a heating coil. I'm having trouble finding a valve that fits my needs and finding accurate pricing data.
Pipe size for both water an steam will be around 1". So far all I've found is the ASCO posiflow proportional control valves. Do I have any other options? What do you think I will be spending per valve?
