O
I'm learning to work with WinCC 5.0 and I've got problems doing tag logging runtime reports. I've created a Dinamic table in the report designer, but when I tried to connect the table with the tag in the process value archive by using the "add..." button, the selection tag dialog box didn't show up. Obviously, I've created a tag archive within a process value archive and it is working without any problems in trends and tables during runtime sesions. Then, what I'm doing wrong?, Is it a bug? P.S. I'm working with a Siemens S5-95U PLC, using the AS511 programmers port driver
