- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
www.control.com/rss
I have a PLC Schneider "Micro TSX 3705" and I want to send all faults massege to mobile. How do I do that, and if that's available, what's the component?
TICO
To accomplish that requirement, I used Maestro 100 GSM modem from Fargo Telecom which have RS-232 serial port, and I connected PLC serial port with GSM modem serial port. So PLC can send or receive message to GSM Modem through RS-232 serial port.
Then, change PLC serial port configuration to text mode, so PLC can send text or ascii character to GSM Modem. To send message, send the AT command AT+CMGS to GSM modem.
Hope this help
look the Schneider Electric W@de modules. http://www.wade-rtu.com
I used for sending SMS form a craine, not only a" water rtu" !!
Best regards!
ZSolt
do you know if there I can do something similar to send SMS from the Siemens S7-200?
I've use the S7-200 with GMS modems to send SMS, check out the Siemens website, look for microset 5.
Marc Sinclair
http://s7-200.germainesystems.eu
I’ve tested the application from Siemens for SMS with the GSM modem. I’ve suceeded to send a single SMS. But the problem is that I have several different alarms to be sent and it is becoming tough to manage the application because it “collapses”: if several alarms occur at the same time the system crashes, and when this occurs, I have to be aware of the reset bit to reactivate the application manually, and... well, I expected something more reliable from Siemens.
Anyway, has anyone already done a project with this library, with several SMS, and it works well?
Thanks,
The microsets are only demonstrations. The supplied code is a bit 'clunky' and the library is, er, non-optimal, the library however is not protected and you can adapt it to your needs. The code is written for the TC65 although I've only ever used the TC35i. I mostly use the CP243-1 IT to send SMS via email, using the GSM route for smaller or movable machines. As for your specific program, I can't comment, but it shouldn't 'collapse' if you work logically. Make sure that you reset the modem, send an SMS, then wait for confirmation before sending another. If there is an error, reset then try again.
Marc Sinclair
http://s7-200.germaiensystems.eu
>the library is, er, non-optimal, <
:) I guess that is the problem with the Siemens microset. I got exited by easily sending the first SMS but then... it is not that good.
>confirmation before sending another. <
The problem is when I get some alarm-triggering conditions simultaneously... I can't make it work, I'm not that expert in PLC programming... :(
I guess if there is a simpler solution out there, like a library or something similar.
>smaller or movable machines. <
I don't plan to use the CP243-1 IT, but I'm curious. :) What does "using the GSM route" exactly mean?
( Complete thread: http://www.control.com/thread/1026242621 )
Here you have a web site where you can download a library for MicroWIN that solves SMS sending with a GSM modem and a Siemens S7-200:
http://www.nubitek.com/section02/pr01-sms_mgr.htm
I worked with that in a project, it's very easy to use and it worked great for me. The library configures the modem, sends SMS to several mobile at once, and it also has a tool to manage incoming SMS (you can recognize the text of the received SMS and activate functions of the program based on that). And no worries for several messages being sent simultaneously, the library manages that transparently. It’s cool!
A PLC based one which is less expensive but with limited features.
A PC based one which may get a bit expensive but also has its own advantages.
For the PC based one, you need to bring your data to the PC. (It's great if you already have a PC-based HMI.) Then you can use off the shelf products for alarm and event notification. One such product is UCMe which can connects to any OPC Server and sends data over SMS/Fax/E-Mail/Phone/RSS Feeds. It has great features like automatic escalation of alarms, alarm acknowledgement, web-based alarm reporting and many more.
Please visit http://www.controlsee.com
Vipul Shah
eGenietech Software Services
http://www.egenietech.com
vipul@egenietech.com
- Colfax Corp. acquires Fairmount Automation
- Oil & gas industry controller benefits from embedded database
- Agreement makes laptops more secure
- TI microcontroller families double performance and battery life
- Online search: Agilent T&M catalog on the Web
- Industrial Ethernet: Most important for process automation system buyers
- SCADA upgrade: PID, supervisory control and data acquisition
- New software: Loop performance technology for power plants
- Customer story: Cement plant implements MPC platform
- Reviewed resource: Profibus PA and Foundation Fieldbus—a cost comparison
