Hi All,
You might have replied to this subject several times, but please bear with me. In era of modern DP smart transmitters do we still need 2 transmitters for 10:1 turndown?
I have a gas flow application (6" pipe line), which must have turndown of 10:1 (2000 - 20000 Kg/hr) using Orifice plate. I have done the calculation for orifice for 250mbar DP and results shows 0.6 beta.
I have two doubts.
1. As we have high accuracy DP transmitters available with 0.025% of span accuracy (As per vendor claims); do we still require two transmitters to measure the flow with 10:1 turndown? What will be the error for low flow (10% of max flow)?
2. Rosemount has launched new models '3051S ultra for flow' which Rosemount claims accuracy of 0.04% reading!!. They say this model can have 200:1 DP turndown with accuracy may be around 0.06% of reading. I believe with this single transmitter I can measure 10:1 flow without reduced accuracy.
Sorry If I am not clear with the concept of accuracy
Dasa
I have two doubts.
Dasa
