Working in thermal power plant with 2x25 mw capacity each governor is 505. When both the unit are connected to grid no problem occurs. But as the grid fails one turbine has to be made master and other as slave. In that case the slave follows the frequency of master. the selection is done manually by a selector switch.
But many times when grid fails the turbine gets tripped due to over frequency.
I want to know is there any option in the 505 governor where it automatically takes the frequency to 50hz when the grid fails?
Pl. HELP
Pl. HELP
