I have loaded the old(not windows) version of Mitsubishi software, Medoc onto my desktop with windows ME and it is fine. When I run it on my laptop which has XP the window size is very small and I cannot alter it.
I have been trying Medoc on XP Pro.
To get it to full screen I had to do alt+enter
then switch between compressed and normal mode
in Medoc. I also found that comms to the PLC would not work with XP Pro.
Two things to check.
Click on the properties on the program icon and set screen size to full on dos window.
if this does not work check your bios and set the LCD panel expansion set to on which otherwise displays only 25 lines on for a dos screen.
When you boot the notebook if you see only a window (for boot display) this is the one to check.
regards,
sekar
I loaded Melsec Medoc 2.3 on two new laptops which has Windows XP but could not get comms to the PLC with either of them. We have reverted to Windows 2000, which works fine. Will upgrade to GX Developer soon.
